Keith
I thought the new registry stuff was supposed to be backwards compatible. Apparently not
though 8^)
I am posting a modified Reg file to Inventor.Customer files. First go to the install dir
(default is c:\Program Files\AutoDesk\Macros) and double click on Uninstall_KWiKViews.Reg
(not the .BAT file). Then unzip the one I posted over the top of the existing one in that
directory and then double click on KWiKViews.bat.
It worked here, so it should get you going. Sorry about that. Guess I will have to
post two versions.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Keith Panik" wrote in message
news:FF841C69B7B69D1FD252856B08C78202@in.WebX.maYIadrTaRb...
> Kent, I assume that since this is posted in the 5.3 NG it is compatable with
> 5.3. I have installed the program, but do not get the KWiKViews under tools.
> Any suggestions?
> Thanks,
> keith
> "Kent Keller" wrote in message
> news:D5C5135297A6583B62A14E85AFA80C90@in.WebX.maYIadrTaRb...
> > A new version of KWiKViews is now available at
> > http://www.mymcad.com/kwik/iCode/icode.htm
> > Hope you find it useful 8^)
> > Kent Keller
> > http://www.MyMcad.com/KWiK/Mcad.htm
> > Assistant Moderator
