KWiKDrive has been updated. You can get it here
http://www.kwikmcad.com/Default.asp?path=icode/kwiktools/addins.asp
Added
The ability of KWiKDrive to work in Parts driving sketch Parameters.
A Reset button to restore the parameter values to what they were when KWiKDrive was
started.
The ability to join two sliders together. Currently this takes a little getting used to.
It basically just does one click for every click done in the driving slider, so if they
are different # of steps they will end differently. Also if the driving one ends before
the driven one it will stop.
A adjustable delay value that when increased makes it more likely that the Escape button
will work. This does slow the sliders way down though, and what I have seen is it takes
nearly a value of 500 to make any difference.
A button that will check for updates if you have Charles AutoUpdater program installed.
Try it out and have fun driving some sketches. 8^)
Enjoy
Kent
Autodesk Discussion Group Facilitator
