Inventor Forum
KWiKDrive Update
0 REPLIES 0
Message 1 of 1
92 Views, 0 Replies
KWiKDrive Update
KWiKDrive has been updated. You can get it here http://www.kwikmcad.com/Default.asp?path=icode/kwiktools/addins.asp Added The ability of KWiKDrive to work in Parts driving sketch Parameters. A Reset button to restore the parameter values to what they were when KWiKDrive was started. The ability to join two sliders together. Currently this takes a little getting used to. It basically just does one click for every click done in the driving slider, so if they are different # of steps they will end differently. Also if the driving one ends before the driven one it will stop. A adjustable delay value that when increased makes it more likely that the Escape button will work. This does slow the sliders way down though, and what I have seen is it takes nearly a value of 500 to make any difference. A button that will check for updates if you have Charles AutoUpdater program installed. Try it out and have fun driving some sketches. 8^) Enjoy -- Kent Autodesk Discussion Group Facilitator
0 REPLIES 0
