Inventor General Discussion
Board Manager
ChrisMitchell01
Message 21 of 41 (881 Views)
Re: Knurled Appearance doesn't show in 2013 Pro
10-01-2012 03:56 PM in reply to: trumpy81
Hi Chris,
These files eem to behave correctly on my machines with the beta SP1 build, the SP1 build & also a newer internal build.
Perhaps the problem lies within the appearance library that you currently have active in your project. Are you also able to share that adssklib file ?
Chris
Chris Mitchell
Inventor Customer Engagement Team
Valued Contributor
ChrisVandeVoorde
Message 22 of 41 (873 Views)
10-01-2012 11:49 PM in reply to: ChrisMitchell01
Hi Chris,
see it attached. It's zipped because otherwise I cannot attach it
Greetings
Chris
Board Manager
ChrisMitchell01
Message 23 of 41 (861 Views)
10-02-2012 05:39 PM in reply to: ChrisMitchell01
Chris,
You seem to have made some changes to the library appearance definitions for the 02_Alu Anodized & Metal-Steel (Knurled) appearances that are cuasing these effects. Looks like you changed the color & also added a reference to a weld bmp file.
Working against my good library, I extracted these appearances corrected them & added them back in to yours & then all seems to work OK again - see attached .adsklib file.
If you temporarily rename your library, then put this in place & rename to InventorMaterialLibrary then use Update from library you should be OK.
BTW - If you're making changes to the libray definitions then I would recommend creating a custom library, adding that to your project definition & then storing changes there instead of modifying the as-shipped Inventor library.
Hope this helps,
Chris
Chris Mitchell
Valued Contributor
ChrisVandeVoorde
Message 24 of 41 (852 Views)
10-03-2012 12:08 AM in reply to: ChrisMitchell01
This works,
So as usual, it was not the PC it was the guy sitting behind :-)
thanks alot for the help!
Board Manager
ChrisMitchell01
Message 25 of 41 (835 Views)
10-03-2012 10:08 AM in reply to: ChrisVandeVoorde
Well, that's very magnanimous of you, Chris; since this relates to the new material/appearance library, how about we split it 50-50 ? Ideally, you shouldn’t have been able to make such changes in Inventor without understanding why/what the end results would be…..
Pleased to help.
Cheers,
Chris
Chris Mitchell
New Member
avedianj
Message 26 of 41 (813 Views)
10-07-2012 04:48 PM in reply to: trumpy81
Just wanted to say thanks to everyone involved in this thread. I am new to Inventor 2013 and have no CAD experience whatsoever and this knurl issue was driving me mad for the last 48 hours until I finally came across this thread. Hats off to you guys.
John
karthur1
Message 27 of 41 (799 Views)
10-08-2012 09:10 AM in reply to: trumpy81
trumpy81 wrote:
Relief Pattern
Type - Knurl      <---- Change the type to Custom Image
Amount - 0.80
Scale - 1.40
After changing to custom image, select C:\Users\Public\Documents\Autodesk\Inventor 2013\Textures\surfaces\knurl_3.bmp then click the triangle to the right of the image to edit the bitmap settings.
Andy,
Are you using Vault by chance?
Kirk
trumpy81
Message 28 of 41 (788 Views)
10-08-2012 01:36 PM in reply to: karthur1
Kirk, no, I don't use vault at all.
I'm not sure I would use vault even if it was installed. I tried it once but I had a lot of problems with it. It may have been my inexperience with it, at the time, but I really couldn't see a need for it. It probably works in a multi-user environment but as I am the only user here it's easier to do without it.
Anytime I need to send models or drawings I simply zip them up. Any changed models or drawings are sent and then overwritten at the other end to save any confusion caused by different versions. So far, this has worked well for me.
HTH
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
karthur1
Message 29 of 41 (782 Views)
10-08-2012 02:31 PM in reply to: trumpy81
No problem.  Only reason I ask if you are using vault, is because when I assign the C:\Users\Public\Documents\Autodesk\Inventor 2013\Textures\surfaces\knurl_3.bmp as a texture and then check in the file, it wants to check the knurl_3.bmp into vault.
Still trying to figure out the "NEW" materials and appearances.
trumpy81
Message 30 of 41 (775 Views)
10-08-2012 05:03 PM in reply to: karthur1
Kirk, I hear ya re: Materials & Appearances. For something that should be quick and easy Autodesk sure have made it difficult. I think I prefer the 2012 setup rather than this new go round.
I recall that I had an issue with that .bmp file also, but for the life of me I can't remember what it was. I think Inventor was complaining about it not being in the project folder, it may have been on an imported part, whatever it was it must have been easy enough to fix because I don't see any errors with it now.
Regards
Andy M
