Hello Inventor Users,
How do I apply a knurl hatching pattern to my Inventor drawing (.idw)?
Textbook figure below from Fundamentals of Modern Drafting by Wallach shows the hatching I'm trying to show in my drawings.
I applied the "Knurled 45" material to the part (.ipt) but didn't see any knurling/diamond pattern applied. When part is added to the drawing (.idw) it doesn't show any attaching.
thanks,
Jeff Jensen
Solved by Curtis_Waguespack. Go to Solution.
Hi jeffjensen,
Here is the method that came to mind:
To edit the hatch, first edit the sketch and then click the Fill/Hatch button again, and then reselect the hatch.
I hope this helps.
Curtis
I just found this related link and picture:
http://forums.autodesk.com/t5/inventor-general-discussion/knurling-in-2d/td-p/2073242
