Inventor General Discussion
New Member
azfalconfixer
Message 1 of 4 (89 Views)
Kill Spline Intelligence
89 Views, 3 Replies
09-16-2009 01:05 PM
Is there a way to remove the intelligence of a spline after it is drawn? I work with splines a lot and sometimes need to trim them but if I don't have lots of points it will move.
Employee
henderh
Message 2 of 4 (89 Views)
Re: Kill Spline Intelligence
09-16-2009 01:46 PM in reply to: azfalconfixer
Hi azfalconfixer,
Instead of trimming, have you tried using the split command?
1) Create a construction line that intersects the spline where you want to trim
2) Use the split command to split the spline (notice it doesn't move, rather it creates a spline point)
3) Now that the spline is split, delete the portion of the spline that is no longer of interest
4) Notice the remaining spline doesn't move or change shape
I know we have the sketch split command in R2009, I'm not sure if is available in earlier versions. I hope this helps.
Best regards,
Hugh Henderson (Autodesk)
Inventor Simulation SQA Engineer
Hugh Henderson
Simulation QA Engineer
DLS
New Member
azfalconfixer
Message 3 of 4 (89 Views)
09-16-2009 02:09 PM in reply to: azfalconfixer
That worked, I've been working with Autodesk tech support but they couldn't figure it out. I'll let them know.
Thanks!
Employee
henderh
Message 4 of 4 (89 Views)
09-16-2009 02:18 PM in reply to: azfalconfixer
Excellent! We're glad to hear it worked, and I appreciate the follow-up.
Please let us know if you have any additional questions, comments or suggestions.
Cheers, -Hugh
Hugh Henderson
DLS
