can anyone help?
I have created a shaft using the shaft generator.
the shaft has keyways in certain journals.
when i create an idw and try to show a section through the keyway, the section view only shows an end view not a section through?
assuming its something straight forward.
thanks
sorted.
I was placing the shaft iam into the drawing.
when you place the shaft ipt from the sub folder it allows the section through to work correctly.
