I have never done this before and I can muddle my way thru it. But what I would like to know is the 'simple' way to create a keyway on a shaft in the middle that does not connect to the ends. End connecting keys are pretty basic to draw and extrude thru (maybe still a better way?) but the middle one is a headscratcher for me.
File attached for viewing and extreme criticism. 😉
TKS!
Solved by IgorMir. Go to Solution.
Couldn't open your file (different IV release) but based on your description here is what I can offer.
Best Regards,
Igor.
That is a basic version of exactly what I was asking. Thank you!
I was looking thru the plane list after I looked at your file and I dont see an 'extrusion plane'. Or did you just rename it to that? If not, how did you go about creating it?
You have to create a work geometry as needed. Extrusion 2 Plane is an offset tangential plane from XY plane.
If you are not using the Shaft Generator - here is another method.
Igor, got it. Thank you!
JD, Shaft Generator? Dunno if that is in your PDF you had previously linked but I have not even thought of trying the shaft generator in inventor. I use it all the time in Mechanical and it never occured to me... thanks for the tip!
