Show only
Search instead for
How can i sketch a keyslot on a shaft? if i create a workplane at certain distance than I am not able to snap/grab the points.
what is the best way to draw anything onb a cylindrical surface? see attached pic, need help
wrote in message news:5244392@discussion.autodesk.com...
Project the center point of the model itself, sketch a (center) line from that center point, then draw your slot. I located it some distance from an existing shoulder by dimensioning to that shoulder, without having to project it, by the way.
----------------------------------------------------------------------------------------- Autodesk Inventor 2019 Certified Professional Autodesk AutoCAD 2013 Certified Professional Certified SolidWorks Professional
schreef in bericht news:5244392@discussion.autodesk.com...
i cant draw key anywhere, it has to be symetrical to axis of shaft, how could i use those points or axis of shaft to draw a keyway on this new workplane
Have you considered using the keyway generator in Design Accelerator?
