Inventor Forum
Keyway on a shaft
8 REPLIES 8
Message 1 of 9
ankittpatel
3334 Views, 8 Replies
Keyway on a shaft
How can i sketch a keyslot on a shaft? if i create a workplane at certain distance than I am not able to snap/grab the points.
what is the best way to draw anything onb a cylindrical surface? see attached pic, need help
8 REPLIES 8
Message 2 of 9
in reply to: ankittpatel
wrote in message news:5244392@discussion.autodesk.com...
project geometry
Message 3 of 9
Project the center point of the model itself, sketch a (center) line from that center point, then draw your slot. I located it some distance from an existing shoulder by dimensioning to that shoulder, without having to project it, by the way.
Message 4 of 9
JDMather
Can you post what you have so far?
Message 5 of 9
Design Accelerator
Jerry
schreef in bericht news:5244392@discussion.autodesk.com...
Message 6 of 9
"if i create a workplane at certain distance than I am not able to snap/grab the points"
What points do you mean?
Put the workplane where you want the bottom of the keyseat, new sketch (F7 to view the sketch plane), sketch the keyseat, extrude cut thru all
-Paul Cunningham IV10sp3a
Message 7 of 9
ankittpatel
i cant draw key anywhere, it has to be symetrical to axis of shaft, how could i use those points or axis of shaft to draw a keyway on this new workplane
Message 8 of 9
ankittpatel
thanks everybody, project geometry would be the right answer for me, thank you all
Message 9 of 9
Have you considered using the keyway generator in Design Accelerator?
