OK, I'm thinking about finally taking the Inventor Certified Professional exam at AU.
Just curious though, are the questions posted at random or are they the same for each test taker?
If one was to get a failing score and then retake the test, could they basically study to the questions they got during the first go-around?
I would think/hope the questions posed would be random as opposed to all being the same set for each taker.
Does anyone know? Has anyone taken it, failed, taken it again and had the very same questions?
Solved by JDMather. Go to Solution.
Failed?
Three people sitting next to each other would get slightly different tests. The problems would cover the same competencies, but the numbers would be different. The problems themselves might be slightly different.
When you retake the exam - you will not get the same test, but it will be very very similar. So the first attempt for you will be good practice. Normally you have to wait 30-days to retake. I am not sure if they enforce this rule at AU.
Make sure you can do Position Reps and View Reps.
Make sure you can manipulate Hole tables in drawings.
Make sure you can do Sheet Metal.
Make sure you can do curve driven pattern.
A list of competencies here-
Create an account here
https://autodesk.starttest.com/
the test questions will be random each time you take it
it does give you a report after taking whether you pass or fail what sections of the test you need to work on
It does not give you an overview of what questions you missed at least i don't think it does
DarrenP
Thanks guys!
That's kinda what I figured/hoped.
I feel if one fails the test, they shouldn't get the very same test again.
Glad to see the test questions are randomized as they should be.
I forgot to ask what might seem like a silly question but....
I've read that one of the bigger issues with the test taking is having to switch back and forth between the test screen and the application, do they offer dual monitors at AU? I figure, that would eliminate that issue.
No biggie if not, a simple alt-tab keystroke to go with the ctrl-c & ctrl-v....;)
I haven't seen them in a couple years, but I used to test the exams. Admittedly at this point they all kind of blend together in my memory, but i've taken tests on AutoCAD, 3ds max, Inventor, and Revit. Passed them as well 🙂
Be warned, there is usually an arbitary question or two. I'd see things like 'what's the name of the dialog box that does this?' And my response would be who cares? Shouldn't matter that I know the name of the dialog box, it should matter I know where to find it and use it.
We'd always leave feedback on the question, we just never knew whether or not they took the suggestions 🙂
I always thought the associate one was harder than the professional one. Associate was the multiple choice test where you don't have access to the program and the professional half was the 'pull up the program and do this and put the answer here' test. That half was always pretty easy in my book. The multiple choice ones had a lot of what seemed to be pretty pointless questions as far as being a top level user is concerned.
There were NOT dual monitors at AU last year. (one large monitor)
The line usually starts early.
I think it starts to fade later in the day.
Go on Monday if they open it up on Monday.
Get used to Alt Tab.
Get used to Alt Tab
Did I mention, get used to Alt Tab.
Here is another tip:
There is usually one question that is "easy" but will take 30-minutes to solve. Pass by it and return to it only after you have finished the rest.
Don't panic if you can't answer the first question.
Don't panic if the practice questions are AutoCAD questions.
