It would be a nice feature to have a control panel in Inventor where you could take certain driven constraints and put them on this control than hit a momentary button to make your model move. Once example would be a hydraulic cylinder. Presently, we drive the cylinder to put things into motion, but I have to access thru browser and usually add symbols to make the constraint stand out (See image). If I had a control panel where I could tie that driven constrain to it and depress a toggle/button which would activate the constrain. I would then have full control and almost act like it would in the real world.
Solved by blair. Go to Solution.
Great idea, you should post in to the IdeaStation
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Great idea, you should post in to the IdeaStation:
What would be wicked cool - is if we could control motion of our DS mechanisms with a game joystick.
Oh man, I could see my students really getting to DS if that were possible.
Thanks Gang...
I was in a rush Friday when I did this and thought I was on the ideastation. Ooops.
It's their now. Would appreciate your Kudos when you get a chance.
Best,
Steve Hilvers
