Is there a way to switch off the animation when creating joints in the assembly environment.
Maybe a reg key or somekthing.
Michael
Hi Michael,
Only the joint type animation may be disabled. The animation I believe you're referring to is when the first selected component moves into place. When we tested Joints we found slapping the component into place disoriented users.This took special work and was intended to help users understand the orientation which is similar rational of transitioning the camera when selecting the viewcube. What I'd really like to understand is:
Since we did special work to support this I'd really like to make sure I get to the root of the issue.
Thank you
Hans Herzog
DLS-UX
Hi Hans,
for new users it´s very helpful feature. But i f you work with Inventor several years you should know what you are doing and this animation in placement isn´t useful anymore. I know you can klick ok and the animation is over but intuitiv every user look this little animation till the end and then click ok. So you waste time with looking animations. 🙂
Helpful would be a slider for the time which is needed for the animation. Similar to camera transition! With option 0 sec.
Michael
Sorry for opening an old topic. I just recently started working with 2014 and googled for a way to turn off joints and got here.
I think the animation of joints is the modern equivalent of the constraint beep: both help a confused beginner
But everyone turns off the beep on the first day of the inventor training...
I want to turn off animations in the application options as well, just below the constraint beep checkbox.
Reason: It slows me down and makes me dizzy. The same reason why websites dont have animations and sounds with every button pressed.
I like the rigid option for placing bolts and nuts, because the constraint - Insert method lacks an option to also fix angle.
Unfortunately Joints do not have an option to 'predict offsete and orientation'.
Also when i add a bolt to my assembly, select the edge on the bolt, then go to the hole I want to insert it, the offset needs to be a negative value.
Also this value disappears and i have to type in the value again and again...
Since I'm using skeleton modelling/mastersketch/topdown modelling, I often only need to constrain content center parts such as bolts and nuts.
I am really looking forward to a 'two-click' constrain method for bolts and nuts without any extra's (like animations). Joints almost hit the mark... Unfortunately it's focussed too much on beginners.
Hi Arnold,
In 2015 an option is provided in Joints to disable the animation so we listened . We also provided several improvements around Joint origins. We support placing orgins between faces and adding x/y offsets to origins. This allows more placement flexibilty lacking in 2014.
Thanks for your continued support and feedback
--Hans Herzog
Principle UX
DLS
