Inventor General Discussion
Member
Deathmetal34
Message 1 of 7 (2,279 Views)
Joining two lines (Straight and fillet) in Inventor 2013
2279 Views, 6 Replies
04-16-2013 02:03 AM
I have searched the discussion groep and have not came up with any usefull information.
I have an inside web plate sketch that i want to offset but my offset does only do one line at a time.
So my problem basicly is that I want it to do the whole sketch in one click. Is it possible to join all the lines? or is there another function that I do not know of that will do this for me.
Please help thank you
Attached is photos of the problem I have
1 picture - How do I join these lines
2 picture - How the whole sketch looks
3 picture - The offset does only do one line at a time (i want it to do the whole sketch)
Valued Contributor
machiel.veldkamp
Message 2 of 7 (2,278 Views)
Re: Joining two lines (Straight and fillet) in Inventor 2013
04-16-2013 02:07 AM in reply to: Deathmetal34
The trick is to NOT use fillets in sketches. I can imagine you know why.
___________________________
Inventor 2012 lastest service pack
RAM: 24GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
Video: NVidia GeForce 680/ HDD: 15.7K
Windows 7 Pro 64-bit
Member
Deathmetal34
Message 3 of 7 (2,263 Views)
04-16-2013 02:28 AM in reply to: machiel.veldkamp
Thanks but the response is not helpful.
Valued Contributor
machiel.veldkamp
Message 4 of 7 (2,261 Views)
04-16-2013 02:31 AM in reply to: Deathmetal34
Do you run Inventor 2012? If so you can upload your model and I could take a look.
Edit: Oops didn't the Title good enough.
*Pro
sbixler
Message 5 of 7 (2,233 Views)
04-16-2013 03:56 AM in reply to: Deathmetal34
Where are the dimensions on your sketches?  When you sketch in Inventor you automatically get connections between adjacent elements (coincident constraints).  When you import from AutoCAD, you have an option to create those coincident constraints, but it's not checked by default.  I see in your first image that your sketch is fully constrained, yet the endpoints are not coincident and I don't see any evidence of dimensions.  How did you produce this sketch?  I strongly recommend that you go over this document in detail, then try your part again: http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
All that aside, you are correct that Inventor should perform the offset on the whole connected path, which it will do if the whole path is connected.
If you go through the above document and get stuck again, post your file here and someone will point you in the right direction.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Distinguished Mentor
swhite
Message 6 of 7 (2,195 Views)
04-16-2013 06:12 AM in reply to: Deathmetal34
If your sketch makes a closed shape you can right click on a line and select close loop, then select all the lines around. This will make the lines a single line entity for your offset.
When you first select offset, right-click a line and make sure your Loop Select option is selected, I believe this is your main problem with only one line being selected.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Curtis_Waguespack
Message 7 of 7 (2,161 Views)
04-16-2013 07:45 AM in reply to: Deathmetal34
Hi Deathmetal34,
Attached is an alternative method that you might consider. It uses more of a 3D solid modeling approach and steps away from the more 2D sketched based approach. The key is to keep the base sketches as simple as possible. I would encourage you to think about your Inventor designs in this way, as I think you'll find Inventor (or Solidworks or Pro-E, etc.) much more accommodating.
More on simple sketches:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
However, if you feel you must create the entire profile in a 2D sketch, I would encourage you to reserve the fillets and offsets for the 3D tools as was previously suggested and simply create your "zig-zag" as an extruded surface to start with, then place the 3D fillets on the extuded surface feature, then use the 3D Thicken/Offset tool to create the solid.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
