Hi Guys! I'm trying to make a part of different tubes by sweeping circles along lines. However one side of the part joins correctly, but other not. I'ill add photos of correct smooth join and uncorrencly unsmooth. Maybe you can tell me a solution 🙂
Solved by CCarreiras. Go to Solution.
Thanks! As I'm new to Inventor everyday i find out new functions 😄 Thank you a lot 🙂 You have saved me at least a week 😄
I second Carlo's comment. Use the Frame Generator as there are some nifty tools in there. Other than that part level trim/sculpt/extrude.
