Inventor Forum
Joining problems
3 REPLIES 3
aki.maxis
425 Views, 3 Replies
Joining problems
Hi Guys! I'm trying to make a part of different tubes by sweeping circles along lines. However one side of the part joins correctly, but other not. I'ill add photos of correct smooth join and uncorrencly unsmooth. Maybe you can tell me a solution 🙂 sujungimai.png
3 REPLIES 3
CCarreiras
in reply to: aki.maxis
Hi!
You can make some surfces and solid trim the tubes... it's a bit hard to explain, post the part, we help.
Btw, Whydon't  you use Frame generator?
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
aki.maxis
in reply to: CCarreiras
Thanks! As I'm new to Inventor everyday i find out new functions 😄 Thank you a lot 🙂 You have saved me at least a week 😄
BLHDrafting
I second Carlo's comment. Use the Frame Generator as there are some nifty tools in there. Other than that part level trim/sculpt/extrude.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
