Sorry baga,
to my knowledge there is not a setting to do what you want.
Admaiora
What you are describing is what is called a foreshortened dimension whether it be a linear dimension or radius.
The size is based on the text and leader arrow size. As far as rotating them, I do not know of a way either. Unless possible through iLogic.
If you are looking to shrink them, you can make these types of change in the styles manager by creating new text and leader styles.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Use the centermark feature and select the arc as shown below. It comes in with extension lines by default. If you only want the centermark and no extension lines, right-click on the mark and uncheck extension lines.
I know how to make a normal center mark.. my question was how can I show the center mark of a jogged dimensions, like on this picture. I haven't found any ways to do it yet
Well, I can't seem to figure out a way to get the center mark that you want either. I don't see any options for the jogged dimension that control this.
The only way is a workaround. I've had this on various wishlists over the past thirteen years, but I guess I gave up and never put it on the Inventor IdeaStation.
The workaround that I have used is to create a very tiny solid feature at the center of the radius, then create a broken view. Inventor will not allow you to create a broken view outside of solid geometry, so you have to create some. Linear dimesions to the center mark will show correctly as in your graphic, but the radius will not jog correctly as shown in the ASME standard. Better than nothing, but not very good, either.
Sam B
Inventor Professional 2015 SP1 Update 3
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Is there any improvement on this? I need to do this some times
No.
Sam B
Inventor Pro 2021.2 | Windows 10 Home 2004
LinkedIn
Dangit, got a long curving part, the radius center is about 5" above the top of the sheet. Seems so easy to allow breaks on dimensions, it already works when there is a part there.
Hi! I need to rewrite my reply to avoid confusion. It is true that the ability to create a foreshortened radial dimension with foreshortened center is not yet available. However, creating a "jogged" radial dimension has been supported for years. You need to edit the dimension style -> Options -> Radial Dimension -> Jogged Leader.
Many thanks!
