Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 7
JD-sheet metal
282 Views, 6 Replies
10-18-2012 04:58 AM
Not sure if you are still going to provide the example in Sheet Metal you mentioned....just let me know if you do not have time and i will cease asking as i would presume your busy
http://forums.autodesk.com/t5/Autodesk-Inventor/rail-holes/td-p/3657028
Best Regards
Terry
Milke already posted solution same as what I would do.
Actually I suggested Unfold/Refold because I was not aware that Inventor would Project Flat Pattern with a Roll Contour (never tried it, but I was thinking about it with your problem, so hopefully I would have discovered the same solution). :smileysurprised:
Either way will work.  I prefer Mike's solution when it will work rather than Unfold/Refold.
The key to Project Flat Pattern is you must start your sketch on a planar face rather than a workplane.
Then select the extants you want to project.
2,122 Kudos
Post 2 of 7
Re: JD-sheet metal
10-18-2012 05:00 AM in reply to: Terry__Close
I will try to get to it today - kind of surprised that someone else didn't jump in here and show a solution as this one is easy.
Did you try the Help with Rolled Contour and Unfold/Refold?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
889 Kudos
Post 3 of 7
Re: JD-sheet metal
10-18-2012 05:20 AM in reply to: Terry__Close
Here's an example of one side. I made up the dimensions, but you can follow the workflow to make your own piece.
Mike (not Matt) Rattray
Valued Contributor
0 Kudos
Post 4 of 7
Re: JD-sheet metal
10-19-2012 05:18 AM in reply to: mrattray
Thanks Mike
Valued Contributor
0 Kudos
Post 5 of 7
Re: JD-sheet metal
10-20-2012 06:20 AM in reply to: JDMather
JD...are you able to how your solution or example?
Cheers,
Terry
2,122 Kudos
Post 6 of 7
Re: JD-sheet metal
10-20-2012 06:30 AM in reply to: Terry__Close
Valued Contributor
0 Kudos
Post 7 of 7
Re: JD-sheet metal
10-20-2012 06:36 AM in reply to: JDMather
Thanks a lot for the help....appreciated
