DETAILS OF THE PROBLEM:
We have many fabrications and so on that we purchase versus make. For example, say that the fabrication is made up of 3 formed sheet metal parts called A, B, and C. On a D-sized sheet say there are thriew views of the fab placed first, say at 0.2 scale. Then details of the parts are put on the same page: views of part A is at 0.5 scale, including the flat pattern; views of part B is at 0.3 scale, including the flat pattern; and part C is at 0.7.
In the past, a "saveas" DXF exported the IDW to a file where each view was: a) exported as a "block" (lines were grouped by view) and, b) each view was at 1:1 despite what thier view scale was in the IDW (appeared to revert to the model true scale). This is VERY important because the exported file would be sent to the winning bidder, and they would copy flat pattern over to thier CNC.
I have tried every combination of setting I could find to duplicate the output we used to get as default. Nothing I did, or friends at Advanced Solutions, got this result, or anything close to it. Settings included every combination of export version (3) AND export view scale (2) options.
WORKAROUND IS NOT AN OPTION, BUT CATASTROPHE
We have hundreds of files like these. Going back and changing all the views to 1:1, adding sheets to accomidate that, and so on, is enough to send our owner through the roof. At a minnimum, he would demand his money back for 8 and ask us to go back to 7. Then when I tell him that we cant change migrated files from 8 back to 7 (that was my first choice as a work around - to use our old copy of inventor just for exporting to DXF), he would swear off Autodesk all together.
I hope this is enough detail.
