Inventor Forum
IV7 Load Speed
17 REPLIES 17
Message 1 of 18
367 Views, 17 Replies
IV7 Load Speed
How long should it take for IV7 to startup? I am talking about from double click to splash screen. I am using P4 2.4, 1024 RAM, 80GB 7200RPM IDE, Quadro 750 XGL.
Thanks in advance.
Dave
17 REPLIES 17
Message 2 of 18
Do you have any virus software "auto protect" on? this could impact startup speed. We have the McAfee and that can almost double startup time, especially the first startup after a reboot. - ed -
Message 3 of 18
It takes about 24 seconds here.
How
XGL.
Thanks in advance.
Dave
Message 4 of 18
We have Norton. I just turned off the "Accessed or Modified" and changed it to "Modified" I'll see what that does. We are seeing 1 to 2 minute times.
Message 5 of 18
Got a correction of sorts to my previous
post.
The 24 second time is after I have already booted
up IV 7, closed it, and reopened it.
When I start IV7 from a fresh computer start
up, it takes around 2-1/2 minutes to open up.
How
XGL.
Thanks in advance.
Dave
Message 6 of 18
xavierl
25 secs to splash screen and 35 secs total until open.
open iv second time. 7 secs to splash screen and 10 secs to open.
this is working local. a network might slow things down.
regards
frans x liebenberg
intel p4 2.3 1GB ram quadro4 550 xgl
Message 7 of 18
xavierl
this is with norton autoprotect running.
one thing with norton. emty recycle bin and purge norton protected files
running norton system works and repairing the registy also tends to speed things up. if you dont have system works you should format your hard drive at least once per year and clean install everything.
regards
fxl
Message 8 of 18
After a reboot it takes about 15 seconds to see splash screen and 23 seconds to see open dialog box. P4, 2.4GHZ, 2GB RAM, QuadroII pro.
Mike
Message 9 of 18
After reboot: 16 sec  to splash, 20sec to
open dialog.
2nd startup: 1sec to splash, 3 sec to
startup.
P IV 2.53GHz
1 GB RAM
GeForce 3 64MB
Win2000 SP2
IV 7 (no SP yet)
RuiF
After
Mike
Message 10 of 18
If you are running ZIP Folders (zipfldr.dll) in XP, this can add
significantly to the time it takes Inventor to do anything.
> Thanks in advance.
> Dave
Message 11 of 18
Where can you turn this feature (Zip Folders) off?
Bob
"Charles Bliss" wrote in message news:3F500DDD.40807@cbliss.com...
> > Thanks in advance.
> > Dave
Message 12 of 18
For comparison purposes:
After reboot: 53 sec to splash, 82 sec to
startup
2nd startup: 7 sec to splash, 24 sec to
startup
P3 450 Mhz
1GB RAM
Oxygen VX1 32MB
Win2K SP3
IV 7 no SP yet
Bob
open dialog.
startup.
P IV 2.53GHz
1 GB RAM
GeForce 3 64MB
Win2000 SP2
IV 7 (no SP yet)
RuiF
After
Mike
Message 13 of 18
Start / Run
and type in:
regsvr32 /u c:\windows\system32\zipfldr.dll
You will need to adjust the directory names to match yours
>Bob
>>>Thanks in advance.
>>>Dave
Message 14 of 18
First start up 4 sec to splash 11 sec to full
load
Second start up 2 sec to splash 6 sec to full
load
Laptop with p4 3.06 HT
this
install everything.
regards
fxl
Message 15 of 18
I can't help with the load speed, but
Norton Anti-Virus can slow things down a lot. I've changed the options in NAV to
exclude Inventor files (.iam, .ide, .idv, .idw, ipn & .ipt) as well as the
.\Program Files\Autodesk\. directory and the workgroup directories, whilst
leaving NAV Auto-Protect enabled.
It speeds things up no end, but some
would no doubt question my sanity after seeing the effects of
MsBlaster.
Hope this is of help.
yours
Duncan Anderson
Engineering
Draughtsperson
SPE International Limited
face="Franklin Gothic Book">
P4  1.9GHZ
1 Gb RAM
nVidia GeForce4 MX 440
[4.4.0.3]
Win X/P (home) sp1[all
updates]
Inv7sp1
NSW2003(incl.NAV2003)+NIS2003 [all updates]
We
times.
Message 16 of 18
Having the latest 3DConnexion drivers loaded with your spaceball unplugged causes a major slowdown on startup as well as the other
reasons.
John Bilton
Message 17 of 18
NAV is a good place to start but have you thought about the
following.......
Check Task Manager to see if you have any CPU intensive apps
running and slowing things down
Defrag your HD (Diskeeper does it overnight automatically for
you)
Keep PCI slot next to AGP card free
Update your graphic card driver, and apply the reg updates
from the IV graphic card website
Put the pagefile on a different partition than the OS and
Inventor install files (preferably a different disk)
Set the pagefile min and max to 4000MB, don't split it up over
many partitions unless using Disk Striping (RAID 0)
Set the Undo file to 1000MB (make sure that you have enough
free disk space for it. set location in IV pull down Tools\App
Ops\File\Undo )
Check your PC for IRQ conflicts, Update drivers\firmware for
EVERY device on your machine (e.g Hard Disk, network card, mouse, soundcard etc
etc)
One or all of these should improve it
Best Regards
Richard Rankin
Manufacturing Solutions (Support)
Message 18 of 18
It takes 2-3 seconds for mine to load up
I am using a system with the same processor, ram and video card as well
I also turn off auto protect while starting up and loading large assemblies
into inventor
Ryan Deline
"theonlytick38" wrote in message
news:f185c83.-1@WebX.maYIadrTaRb...
Quadro 750 XGL.
Thanks in advance.
Dave
