I'm creating an IDW that will have individual small views of multiple parts.
I find myself doing at lot of rearranging view locations to fit as many parts per page as possible.
Each individual part will have a front view and a side view.
Here is my issue. If I move the front view up and down the side view follows it as expected.
If I move the front view left and right I then have to move the side view to match the new location. I hope that makes sense.
Is it possible to lock the distance between the views so the side view follows the front view in whatever direction it moves?
Thanks in advance,
Richard in Houston
It seems like this would relatively easy to do. When the side view is created it's by default aligned with the front view. If you could then lock the spacing between the views that would solve my problem.
I will have to admit that in 10+ years in Inventor this is the first time I've had the need to do this, so this would fall in the category of extremely minor problems. 🙂
Harkens back to my old days with paper and the mechanical drafting arm and having to plan the drawing to get the views all evenly spaced. This might be a good one to post on the IdeaStation: http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
