Can anyone point me to any help or tutorials on using Joints?
Not the joints associated with dynamic simulations but the Joint command that is next to Constrains on the Assemble menu panel.
It could be a 4 day weekend hangover or just my general state of confusion but I'm not having much luck finding anything.
Thanks in advance,
Richard in Houston
Hi!
Why don't you stay with the traditional constrains?? They are easier to manage and you can do with them all what these new useless joints does.
I only can see some utility in these joins if you will test with the dynamic module... if not, my advice is: use deeper all the functionalities that traditional Constrains have... and you will have better weekends :).
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
