Inventor Forum
IV2014 Constrain Cylinder Axis to Multipart Slot Centerline
3 REPLIES 3
hfds006
657 Views, 3 Replies
In the attached image I have the blue pin constrained to the straight slot and it's travel is restricted to the length of the slot.
The red pin fits into the two part slot.
Is it possible to constrain the axis of the red pin to the centerline of the two part slot?
3 REPLIES 3
CCarreiras
in reply to: hfds006
Hi!
You can use a transitional constrain to achieve that.
First in the Yellow part copy the 3 lateral slot walls as a surface. Then you can use this surface and the cilinder wall to constrain.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
CCarreiras
in reply to: CCarreiras
Hi!
Check the video in attach..
CCarreiras
hfds006
Thanks, that's exactly what I needed.
