you have to edit the setup.ini
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/How-To-Install-AutoCAD-2014-WITHOUT-Autod... this applies to all suites and products not just Autocad
DarrenP
OK so I have to do this for each "flavor" of deployment I develop. The linked thread seems to be mostly talking about AutoCAD but I assume this ini edit takes care of all the softwares.
yes this applies to all 2014 suites and products that come with Autodesk 360
DarrenP
OK thanks.
So I did some looking through the setup.ini file to see what the thread you had pointed me to was referring to.
It states to remove the ADSYNC argument from the statements that start with POSTREQUISITE but it only shows the one example like it only appears once.
However in searching the ini for Product Design Premium I find thic combination in four areas of the softwares being installed.
Inventor
Showcase
ACM
Acade
I would assume that the ADSYNC should be removed from all the cases to totally keep it out.
Also there is a section in the ini that defines ADSYNC as Autodesk Cloud Sync. Within that section there is a statement that say Action=Install. I am wonder if there is a proper arguement to that action statement that would just cover Not Installing.
