One of our IV2012 stations is giving the operator a strange message. Any ideas? This comes up when he tries to get into application options.
Enter a number between 0.2 and 5.
See Attachment
i suppose there is some problems in your last operation before getting into application options, can you give more information here ? you can try to save your files then close & relaunch Inventor.
Kevin Li
Running Windows XP
We have already closed all files, rebooted, relaunched Inventor, still happens.
Did anyone figure out how to fix this? I am now getting the same error message... "Enter a number between 0.2 and 5." when i try to enter application options.... i am using Inventor 2012....
Hi, I know this is an older thread but I am having the same issue as the original poster.
I am using Inventor 2013 Design Suite Premium on a Windows 7 64 bit professional O.S.
Inventor crashed on me and when I opened it up and went to change some dimensions on a sketch, the leader lines were there with no arrows and no dimension numbers. I was able to edit the dimension though. Figuring I might of changed the dimension style somehow I went to go into the Application options and got the same message as the OP.
Was there ever a solution to this problem?
