Hi robtupa,
There are two things happening here:
1. AUTO-PROJECT GEOMETRY: If you check, Tools, Application Options, Sketch, Autoproject Edges for sketch create and edit, then you see the behavior that you attached in the AVI. I created something ver similar. projectuser.ipt. If you see Sketch4, it has only the circle. When you edit Sketch4, since this option is checked we are REPROJECTING the edges to the sketch. So, the projected edges were not there in Sketch4. When Sketch4 was consumed by Extrusion5, we deleted all the auto-projected edges from it. Therefore when you put the mouse in the browser on Sketch4 you only see the circle. This behavior is so because why carry unnecessary auto-projected edges in the sketch when it is not used.
I suspect you have this option checked.
2. MANUALLY PROJECT GEOMETRY: If you manually project the edges then you get the desired behavior (Use Project Geometry in the Sketch edit or create panel bar). Uncheck Tools, Application Options, Sketch, Autoproject Edges for sketch create and edit. I created project.ipt. If you observe Sketch4 here you see the circle and the projected edges. Here if you delete Extrusion4, and uncheck consumed sketches in the dialog that appears later, then the projected geometry is not deleted.
So, if you want projected geometry to be not deleted, project it manually.
>When I edit the sketch, everything appears as it should
Because we are reprojecting
>When I edit the feature in order to select more profiles to extrude, I can't
This is because the projected edges are not there in the first place.
>Don't show the edge projected edge lines in sketch mode if they don't contribute
Because of reprojecting we are showing it.
Did I muddy the waters more? Does this make sense?
Thanks.
shekar
