The problem is that iProperties must be seperately and manually accessed in order to be edited. Would having an opition to prompt for iProperties (or some form of it) when the drawing file is created be possible to add to a template?
Also, if you do the drop-down option box, could you also add that to iProperties?
Don't forget to check the dates on posts you are replying to! Five years and seven versions later, there are other ways to handle this, such as iLogic.
