Constrained a tube axis 90 degrees to base, then measured angle.
First time got the attached error, restart measure command would
not work, had to dismiss and restart. Then I would either get
0 degrees like I should, or some ridiculously small angle
(0.00000085377365 deg), which then also triggers having to
dismiss the measure command and restart it to continue.
Anybody else ever get this error?
Bob S.
