In the resolve dialog, browse to that subfolder, then make sure that
location is checked for search also.... does that help?
Dennis Jeffrey, Inventor 9/10 Professional user
Autodesk Inventor Certified Expert
Manufacturing Solutions Implementation Certified Expert
Autodesk Product Consulting and Training
(260) 312-6188
Omicron Electronics -Center for Design Excellence
http://www.omicronmi.com
http://www.design-excellence.com
260-312-6188
wrote in message news:4912485@discussion.autodesk.com...
Dennis
Thanks for the reply, I've already got that checked, and I must admit that
seemed to be what it was for, unfortunately it does not work.
My problem stems from a R9 assy, with standard parts in a certain location,
before I migrated the assy, the standard parts location was changed without
my knowledge, my proble is that my part has been moved to a sub-directory of
the original location. I thought it would be a simple resolve link issue,
but no, I try to manually resolve each part but I have over 150 of the
little Bu@@ergs in there. Now I have made some changes to the assy and need
to open the IDW and make sure all is ok, but of course I cannot open an
unresolved idw, bit of a catch 22.
I would have thought I could simply add a new library path in the project
but I cannot edit this, as it is greyed out (I assume because I do not have
the rights to do this).
Are there any work arounds that you now of that might help.
Thanks for help
Bill
