sorry, found it!
"John Ricketts" wrote in message
news:4858467@discussion.autodesk.com...
Is there any way to change the hole-note default so that tap drill (or at
least, thread depth) always gets shown in hole tables and notes for blind
holes?
Why do my blind tapped holes show by default as "M6x1 - 6H" when its obvious
that the default should case show the depth! This becomes a real pain when
you have a hole table with 20 holes in (all the same thread, same depth) and
you have to change them all to display correctly. Also, if you select the
option to combine the notes in the table, and click on the combined note to
select "tap drill" it picks them off one at a time and you have to do it 20
times (unless I'm missing a trick)!
John
