Show only
Search instead for
we have iv10sp3, (network ver) and vault 4, (on server) One of our engineers wants to use 11, (without vault 5) for one particular project, becuase of the extras you get with 11, is this posible?
Different releases of Inventor can be installed side-by-side on the same
machine but only one Inventor can be run at a time.
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
"Rick Donnellon" wrote in message
news:5205202@discussion.autodesk.com...
Is there any problem loading IV11 on a machine that IV10 is loaded on?
Actually, you can run more than one Inventor at the same time, as long as
they are of the same version. (i.e. you can run two R11's at the same time,
but not an R10 and an R11 at the same time)
Best regards,
Hugh Henderson (SQA Engineer)
"Johnson Shiue [Autodesk]" wrote in message
news:5205934@discussion.autodesk.com...
Johnson Shiue
Test Engineer
