So I'm running IV Pro 2014. Seemingly at random but much more frequently now IV will work stupid slow. Drawing a line in a 2D sketch can take 30s. Now when I unplug my computer from the LAN it tends to work for about a few minutes and then does the same thing. This happens whether I'm looking at a model on my hard drive or the network. No one else seems to have this problem. We just reinstalled IV on my computer to no end.
So far IT has been no help and I was wondering if someone else might know some of what's happening.
Solved by johnsonshiue. Go to Solution.
Are you using a 3D Connexion device?
If so, go into the 3D Connnexion Control Panel and click Calibrate (or try unplugging it) to see if that makes a difference.
(I assume you have installed SP 1 & 2.)
Also, I recently had some mal-ware on one of my machines that was making Inventor dog-slow.
(the mal-ware would show itself after running Chrome and then Win L to lock my machine, upon returning - random web pages would show although no web browser app shown as running) Even when the mal-ware was not showing itself - the computer was running slow until it was cleaned. This one was particularly difficult to clean.
Hi! A few things come to mind. Could you try the followings and see if it makes a difference?
1) Turn off other applications.
2) Go to All Programs -> Accessories -> System Tools -> Disk Cleanup. Make sure all temporary files are deleted.
3) Start Inventor and go to Tools -> Application Options -> File -> uncheck "Enable Quick File Open" -> Apply and OK.
If none of above helps, please record a video showing the behavior.
Many thanks!
Open the Task Manager and look to see what application(s) are hogging your system resources.
