Inventor Forum
IV closes to desktop when constraining
15 REPLIES 15
Message 1 of 16
279 Views, 15 Replies
Inventor does a complete close when I try to use any constraint command in
an assembly.
I just did a repair re-install to fix a previous problem and now I have this
new problem. Is there a fix to this??
Josh
15 REPLIES 15
Message 2 of 16
jmartzig
this was happening to me this morning on a sheet metal part. total pita! what i did, was "save as" the part. deleted the original, then re-inserted the one with the different name. for some crazy reason it worked. worth a try for you. lemme know if it works. -Joe
Message 3 of 16
Joe
That suggestion you had for me didn't change the
outcome for me.  I still get the complete close to desktop...
This really stinks!!!
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
this
Message 4 of 16
jmartzig
sorry josh. how are you doing on hard drive space? have you cleaned your temp directory? try those 2 things too. and since this problem just started to arise.....i'm assuming you are NOT using an ATI video card, right? -Joe
Message 5 of 16
If it's not something related to a specific part (?) and problems appeared
after the "repair" I'd consider a clean-out and fresh install.
"Josh Beissel" wrote in message
news:9AB21F627795650734571D6A9C6AC27D@in.WebX.maYIadrTaRb...
> an assembly.
> Thanks
> Josh
Message 6 of 16
Hard drive space is good.  Temp directory is
clean.  And I wouldn't touch an ATI with a ten foot pole!!
I've got an NVidia 750XGL.
sorry
-Joe
Message 7 of 16
Pre sp1 I experienced this a couple of times in the same assembly when constraining between 2 parts. I resolved it by moving one of the parts to another location then constraining it. All this while working in XP Pro, I would get the usual "...Inventor Error Message...", hit "don't send", then Hello desktop. Post sp1 I have some occaisional "constraint lockups", if I let it sit (0% cpu usage while waiting) Inventor will return. If I don't let it sit and try to pick something to re-initialize it, I go straight to desktop, no message. Mike
Message 8 of 16
....just one additional thought. In some previous release I remember having
problems with a combination of adaptivity and the constraint preview (Gloria
III). If you normally (I do) run with the preview turned off, doing the
repair probably reset it to on.
"Jeff Howard" wrote in message
news:450EC4F7C1EACE53B816611BE3A25DCA@in.WebX.maYIadrTaRb...
> > an assembly.
this
> > Thanks
> > Josh
Message 9 of 16
rllthomas
Could try nuking the current user section of the registry pertaining to IV. Sometimes that helps although I haven't had to resort to that since R4.
If you don't know exactly what I'm talking about DON'T DO IT!
Rich Thomas
Message 10 of 16
I've only started seeing this problem since
installing Sp1.
Could
R4.
IT!
Rich Thomas
Message 11 of 16
Jeff,
I had one assembly that would cause a crash on my notebook, but not on my
workstation. Just tried it with preview OFF - and it worked. Hmmm.
news:5DE1A9625664F4721B46F75205DF21C0@in.WebX.maYIadrTaRb...
having
(Gloria
appeared
command in
> > > an assembly.
have
> this
> > > Thanks
> > > Josh
Message 12 of 16
I just uninstalled and re-installed IV 7 Without
Sp1.
this time and did performed the same constraint as
earlier, this time it worked no closing of IV.  There must be
something in Sp1. that my computer doesn't like.
installing Sp1.
Could
R4.
IT!
Rich Thomas
Message 13 of 16
Josh Beissel wrote:
> I just uninstalled and re-installed IV 7 _Without Sp1._ this time and
> did performed the same constraint as earlier, this time it worked no
> closing of IV. There must be something in Sp1. that my computer doesn't
> like.
Re-install SP1 and try it, it may have been related to your original R7
installation.
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4351 drivers
Dell UltraSharp 19" LCD
Message 14 of 16
I posted this problem dated 6/06 in this NG but I still am not sure what
caused it, although it's gone now.
ncabilan
news:8D334BB926D7273DBEC5BDE9C9E895E4@in.WebX.maYIadrTaRb...
I've only started seeing this problem since installing Sp1.
"rllthomas" wrote in message
news:f170cc8.7@WebX.maYIadrTaRb...
Rich Thomas
Message 15 of 16
Yeah, it's strange stuff. I guess it indicates there is a conflict of some
sort, but it's really hard to pin some of this stuff down. I've just gotten
in the habit of keeping two things off; constraint preview in IV and autosave
in MDT. I'm a bit odd and consider both to be an annoyance for the biggest
part, anyway. 8~)
"Ron Crain" wrote in message
news:8D82BC60E7454A87F4AE96158FD2195D@in.WebX.maYIadrTaRb...
> Jeff,
Message 16 of 16
Good morning, (so far)
I just re-installed Sp1. and all seems "normal". I did test adding a couple
of constraints to my assembly and had no problems even while using the
preview.
Thanks to everyone that helped me out, much appreciated..
Josh
Felling Trailers.
"ncabilan" wrote in message
news:48161AED22A1D033D328345C3C4B5354@in.WebX.maYIadrTaRb...
> ncabilan
IV.
> Rich Thomas
