When I try to load the stress analysis enviroment in IV 2014 the ribbon has no buttons except for the check mark.
The add-in is loaded.
Any ideas?
See Attachments.
Solved by Greatwhitenorth. Go to Solution.
Do a right-click in the grey area at the end of the existing icon row, and select Show Panels. Turn on the ones you want.
HTH
Bob
Hi
I have similar problem, but me missing card in ribbon.
When i set user buttons (in any card in ribbon) and start FG analysis, commands work, button for the end of FG analysis are available,
only the card of ribbon not displayed.
I use: repair, automatic reinstall, reregistration, BAT file from autodesk web (in bin folder, see me text: no internal or external command) but this is not solution.
Any tips
Thanks for help
