Inventor General Discussion
Active Contributor
7 Kudos
Post 1 of 3
IV 2013 Keyboard Shortcuts not working
423 Views, 2 Replies
01-02-2014 08:59 AM
Any other ideas on what's going on? The two threads I found don't seem to have a firm solution. We're currenlty on SP2
http://forums.autodesk.com/t5/Inventor-General/Inventor-2013-Pro/m-p/3512526/highlight/true#M439521
http://forums.autodesk.com/t5/Inventor-General/Hot-Keys-Not-Working-Inventor-2012-SP1/td-p/3288719
This is the particular setting we've setup for iProperties that worked fine in 2012:
Here's what it looks like when you actually type the letter:
Anything else I should check settings-wise that may be causing this?
Inventor 2013 SP2 Build 200
Vault Professional 2013 Build 17.1.16.0 Update 1
AutoCAD 2013 SP2 G.204.0.0
NavisWorks Simulate 2013 10.2.0.91043
PLM360
If you sort by your keys you will find that you have a number of Aliases assigned to P:
Default Inventor 2014
Default Inventor 2013
I expect that the environment that you are in is Cable and Harness.
You might want to choose a more unique alias like IP.
Please try this and let us know.
Product Support
51 Kudos
Post 2 of 3
Re: IV 2013 Keyboard Shortcuts not working
01-02-2014 10:13 AM in reply to: bruce.buck
Bob Holland
Active Contributor
7 Kudos
Post 3 of 3
01-02-2014 12:40 PM in reply to: bob.holland
You are correct. Didn't notice that same keys could be assigned in different environments. Although I'm not explicitly in the cable/harness environment when doing this (usually just in an assembly/part environment), I can see where the mixup can occur. Will look at a different approach for this situation. Thanks for your help.
PLM360
