Yesterday i installed IV 2012 (Ulitimate 2012).
Today i wanted to migrate some files using the Task Scheduler.
This is what i got (see image).
Has anyone seen this before.....? Tryed a few things (new install, repair, register etc.) but no luck.
Please some advise..... Thanks.
Finally the reason for the problem was found out. This is caused by a conflict between function in TaskScheduler.exe and a dll file. The workaround for the moment is to restart the machine in Safe mode, then the Task scheduler buttons should look correctly. The problem will be fixed in SP1, we are also discussing currently the possibility to create a hotfix for this issue.
