I'll be out most of the day, but I'm sure someone will take a peek.
In order to post here, the file must be zipped,
and under 1.5MB in size. If the file is larger than that, then post the
files at
this location:
You can post the file as is to ftp.interlancentral.com -
month>2007
folder.
Create a network place OR use Internet Explorer to post.
In IE, Select File > Login
username: newsgroup password: Inventor1
This is the location that the Autodesk newsgroups use to post large files.
Keep in mind that it is a public site, just like this newsgroup.
Full information is located in the FAQ that is posted here weekly by Kent
Keller.
Let us know in the this newsgroup when you posted it.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
"Rich Honchen" wrote in message
news:5655482@discussion.autodesk.com...
Yes, I actually re-created the entire assembly after SP1 and ended up with
the same error. Rebuild all does have an effect but does not resolve the
error. I place the parts to be cut first and make the assembly cuts and
everything is fine. After adding and constraining most of the additional
parts, the assembly cuts fail. I was placing a part that had nothing to do
with the assembly cuts, dragged it to move it close to position and the
error popped up. I can post the files if you are interested in looking at
them.
Thanks for your help
Rich Honchen
"Dennis Jeffrey" wrote in message
news:5655354@discussion.autodesk.com...
Sorry, meant; have you done a Rebuid All after installing SP1. No coffee yet
this AM...
260-399-6615
news:5655362@discussion.autodesk.com...
shekar,
I have submitted a support request #1-2208467437 and received a reply from
Colin Riley. The files are uploaded to the support request. The assembly
was created from scratch in IV2008 from migrated components and the error
occurred later on while adding and constraining additional components. I
then discovered and installed SP1 and re-created the same assembly but had
the same result. Thank you for your help and please contact me if you need
any further information.
Rich Honchen
wrote in message
news:5654890@discussion.autodesk.com...
Rich,
If it worked in R11 and it is failing in R2008 then it sounds like a issue.
We would like to investigate. Can you send the file?
shekar.subATautodesk.com.
Thanks.
shekar
