I've just started working on a frame generator assembly I was modelling earlier this year; I can't seem to modify the base 3D sketch. The feature which looks like the original 3D sketch is now called the "Reference Skeleton" and I am unable to modify it at all. Could someone explain how I can modify this? I am (obviously) quite new to Inventor.
I am working on a copy of the original part as I "save as" the whole master assembly when I was last working on the model. I don't know if this would have effected anything.
Any help would be greatly appreciated.
Tom
Solved by JDMather. Go to Solution.
That is not the sketch to edit.
You skeleton part (and sketch) should be the first node in the browser.
Open the file HTC-P009.ipt
