Inventor General Discussion
BarryZA
Message 1 of 5 (152 Views)
Issue with 2013 update 4 SP2
152 Views, 4 Replies
03-13-2014 12:06 AM
I am still on 2013 Pro 64 bit. After a few crashes recently I installed SP2 and encountered an issue:
If I have an assembly open and change tabs, then come back to the assembly, a whole lot of the parts have dissapeared from my screen.
The only way to get them to appear is to click on them in the browser.
Tried installing update 4, but it dosen't help.
(Win 7 pro, 64 bit)
If I can't resolve this I suppose I need to do a system restore.
Is your video driver up 2 date?
Try also the Hardware settings in the application options. Switch to a different one and then switch back to what you had before (I my case that's Performance) ,that action makes sure the registry files are reset.
stefaanboel
Message 2 of 5 (142 Views)
Re: Issue with 2013 update 4 SP2
03-13-2014 12:47 AM in reply to: BarryZA
If this is the solution, push the solution button :smileywink: (and maybe some kudos)
BarryZA
Message 3 of 5 (137 Views)
03-13-2014 01:05 AM in reply to: stefaanboel
Thank-you squire, looks like I've opened a can of worms here.
O, for a unified update manager like in Ubuntu :smileywink:
BarryZA
Message 4 of 5 (105 Views)
03-13-2014 10:01 PM in reply to: BarryZA
Solved!
One "complication", I had to close all my tabs in Inv. first, before changing the hardware settings for it to work.
Much obliged.
stefaanboel
Message 5 of 5 (96 Views)
03-14-2014 12:30 AM in reply to: BarryZA
Great!
Thanks for the extra info, I'll remember the "close all tabs" part :smileyhappy:
