Inventor General Discussion
Active Member
harris.1782
Message 1 of 2 (149 Views)
Issue with 2010 Inventor
149 Views, 1 Replies
07-09-2012 08:25 AM
when a rectangle is drawn with dimensions 44 wide by 79 height in inches it becomes a slanted rectangle. Other versions of Inventor I have used don't do that is there a way to fix it?
Hi harris.1782,
You've likely toggled off your Constraint Inference and/or Constraint Persistence buttons.
This link from Paul Munford covers these tools and how they work:
http://cadsetterout.com/inventor/temporarily-turn-off-inferred-constraints/
Or you've turned off the inference for just some of the constraints.
Check this by right-clicking while in a sketch and choosing Constraint Options:
I hope this helps.
Good luck with all of your Inventor pursuits,
Curtis
http://inventortrenches.blogspot.com/
Curtis_Waguespack
Message 2 of 2 (144 Views)
Re: Issue with 2010 Inventor
07-09-2012 08:41 AM in reply to: harris.1782
Hi harris.1782,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
