Inventor Forum
Issue - Color Mobile Groups - DS Welded group
2 REPLIES 2
JDMather
420 Views, 2 Replies
If I try to change the color of a Welded group there is nothing avialable in Appearance.
The other mobile groups I can change.
I have not checked to see if the problem is specfic to current dataset.
More to follow.
2 REPLIES 2
JDMather
in reply to: JDMather
Here is a dataset.
Should be able to change the color of the Mobile Group (Welded).
Edit
 Hmm, I don't think I have ever seen that happen before - I downloaded my dataset to check again and the Joints had changed.  New dataset comming in a few minutes.
Well,
in the process of going through this I think I uncovered at least two more "issues" and maybe three.
Unfortunately I don't have time to fully document.
but in short -
I used a Revolution Joint in assembly environment
turned off autoconvert of constraints to joints
welded
I could Color Mobile Groups, and got expected behavior to that point, but then could not change the color.
Save closed and posted dataset 1.
Opened and my DS Joints had changed.
Deleted and manually added Revolution in DS.
Color Mobile Groups resulted in everything going transparent - including the mobile group. (dataset 2)
innovatenate
I can reproduce this issue from scratch. I will file a report with the development team, promptly. Thanks for posting this!
Kind Regards,
Nathan Chandler
Principal Specialist
