Inventor Forum
Isometrics Help!!!!!!!
1 REPLY 1
237 Views, 1 Reply
ok so i tried the work point and it still would not let me get a dimension.
then i tried doing the retrieve dimension feature that worked it gave me the dimension but not on the right dimesion plane. i anyone knows anything please help.
thank you.
1 REPLY 1
JDMather
In a case like this I would click on the view and hit S to start a new sketch and sketch the needed geometry.
The problem is that hole edge creates a spline rather than a circle.
In certain cases - you might be able to add some tiny geometry to the model to fudge what you need - but this might cause problems if go all digital from CAD to CAM.  (add a tiny revolve cut at the center line - fudge to give a circle)
