Inventor General Discussion
Member
KyleMJewell
Message 1 of 12 (839 Views)
Isometric Shaft Dimension
839 Views, 11 Replies
04-09-2012 10:09 AM
Trying to dimension a shaft in isometric view with various diameters. I am unable to find or select the centerpoints at the ends of the shaft. This causes dimensions to be crooked. How can i get the centerpoints to display so that they may be selected?
Curtis_Waguespack
Message 2 of 12 (824 Views)
Re: Isometric Shaft Dimension
04-09-2012 10:48 AM in reply to: KyleMJewell
Hi KyleMJewell,
If you select the arcs with the General Dimension tool you should get the result you're after (be sure not to select the green dots though). Note that you can use the Space bar to toggle through the avalable placement planes.
The green dots are object snaps. If you start the General Dimension tool and then right-click you should see a Snap Settings flyout menu, where you can control which snaps show up. But I don't you need to adjust these in this particular case.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Curtis_Waguespack
Message 3 of 12 (804 Views)
04-09-2012 11:04 AM in reply to: KyleMJewell
Hi KyleMJewell,
Also, once you've selected an arc you can right-click to find the Diameter and Use Sheet Plane options for the diameter dims.
I hope this helps.
Curtis
Member
KyleMJewell
Message 4 of 12 (795 Views)
04-09-2012 11:11 AM in reply to: Curtis_Waguespack
This method works if there is no modification to the shaft such as the threads or woodruff keyseat which prevent it from automatically recognizing centerpoints. I have tried several times and it still does not work.
Curtis_Waguespack
Message 5 of 12 (790 Views)
04-09-2012 11:14 AM in reply to: KyleMJewell
Hi KyleMJewell,
Can you provide us an example part file that demonstrates the issue you're seeing?
I hope this helps.
Curtis
Member
KyleMJewell
Message 6 of 12 (780 Views)
04-09-2012 11:22 AM in reply to: Curtis_Waguespack
Here is the part that I am having trouble with dimensioning. You may notice that the thread is coil cut because I needed it created that way.
Curtis_Waguespack
Message 7 of 12 (754 Views)
04-09-2012 01:27 PM in reply to: KyleMJewell
Hi KyleMJewell,
You're correct it is the coil cuts that are causing the issue, since they result in an edge that isn't a true arc. Unfortunately, I didn't really see an easy solution to placing those dimensions in that view. The best I could do was to turn on the hidden lines and scrub over each edge until I located the (very tiny) edge that was an arc, and then I used that to find the center point. Then I turned off the hidden lines.
I'm not sure that provides a very robust solution,  but it did work.
I hope this helps.
Curtis
KristopherReaves8819
Message 8 of 12 (748 Views)
04-09-2012 01:45 PM in reply to: KyleMJewell
Out of curiousity have you tried putting work points on your part prior to any modification cuts, then bringing those work points into the drawing for the dimensioning and either switching them to a different point style or turning them off after your dimension is set.
It should be a bit more 'robust' for future changes in length and you have points at the centers that can be used. I have always found that though a face/feature may change drastically if I put a work point at the right step my part will be extremely robust and almost impossible to break, the dimensions on drawings rarely drop out for that matter on the finer details.
Kristopher Reaves
Member
KyleMJewell
Message 9 of 12 (706 Views)
04-10-2012 10:53 AM in reply to: KyleMJewell
When i attempted the work point method i was not able to grab the point when dimensioning.
cbenner
Message 10 of 12 (648 Views)
04-20-2012 08:29 AM in reply to: Curtis_Waguespack
Curtis,
Does this only work with Radius or Diameter dimensions?  In the picture below, I'd like to get the notes and linear dimensions onto the same plane... one or the other, I have no preference which.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
