Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
I arrived at the same solution. If you modify the dimension style Line:Color = white (Display Tab), the dots will disappear. There is also a 'Hide Extension Lines' option Dimension Styles (using inventor 2012).
There are also arrow placement options in the Options Tab of the Dimension Styles dialog. Using all these options there is no modification necessaty after placement of the dimension, other than modifying the text.
