Hi folk,
Its possible create through Design Accelerator ISO 606 Chains but with support plate like standard?
Please see the attached file.
Thanks in advance
(Inventor Pro 2014)
Solved by MariaManuela. Go to Solution.
NO FILE ATTACHED
Looks like the Autodesk News Group System/Server is striping files off YET AGAIN when posting using IE10/11. At least thats the problem I've had for the past week or so.
Best off using Google until they get off their hint ends and fix this latest Balls-up
FILE HERE
Thanks for advice.
Mail from Autodesk:
"Dear Manuela Pinho,
Thank you for choosing Autodesk Support.
This standard is not existing in Inventor currently. The ISO 606 basic chains are included in the Inventor library. Also, when you create a roller chain mechanism, you do not get the chain generated, but only a line representing the chain. This is done for performance reasons. If you want to create a full chain representation, you can use this utility: http://www.mechatronic.me/cad Roller chain Generator for Inventor
I hope this helps.
Best regards,
Daniela Koloszko Autodesk Support Team"
