I'm making an assembly and it requires rules and iparts/iassembly. The issue I'm having is when I using the iAssembly it changes the name of a part (ex. "TEST:1" into "TEST1:1". When that changes the Rules loses it because of it having a different name... How can I get around this?
Hi ASchlaack,
I might not be recalling correctly, but I think the generally suggested method is to "Stabilize" the iAssembly member names. See these links, and/or search the forum for "ilogic stabilize" or "ilogic stabilized", etc.
http://forums.autodesk.com/t5/Inventor-General/Placing-Components-with-iLogic/td-p/3037716
I hope this helps.
Curtis
