Inventor General Discussion
Active Member
rabruce
Message 1 of 4 (166 Views)
Is this an error?
166 Views, 3 Replies
05-28-2012 02:44 AM
Could someone please advise me what the lightening symbol means next to a bolted connection in an assembly.  Is it an error or nothing to worry about.  See attached JPG screen grab.
Valued Mentor
Mason-Paul
Message 2 of 4 (156 Views)
Re: Is this an error?
05-28-2012 04:11 AM in reply to: rabruce
Bolted Conection 43 Assembly file needs to be updated.
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
PaulMunford
Message 3 of 4 (147 Views)
05-28-2012 05:21 AM in reply to: rabruce
Something in your assembly has changed, and the Bolted connection is telling you it wants to be updated.
Right click on the Bolted connection and chose 'Edit with Bolted connection generator', Check the inputs and if all is well, just close the generator agin to update the Bolted connection.
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Cadmanto
Message 4 of 4 (129 Views)
05-28-2012 07:07 AM in reply to: rabruce
Also try using the rebuild all command in the manage tab on the ribbon.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
