> {quote:title=pauldoubet wrote:}{quote}
> OK, I should have read your OP more closely. I did not realize the actual problem you are having was with placing a component from your custom library with Bolted Connections. I am not using 2010 at the present time but I don't think anything has changed regarding what you need to do to correct this problem. After you create a custom library you have to add that library to your active project using the ADMS console before it will show up and be available for use. Did you do that? It will show up in the Content Center editor as per your screen shot but it won't show up in your project.
> Paul
I can use it fine. I can place all of my custom parts into any of my assemblies, by using the "Place From Content Center" button, and the Bolted Connection Generator. My problem is that the Bolted Connection Generator does not see my custom Hex Nut's family name correctly. It is still showing the default "Hex Nut - Inch" family name when it should be showing my custom "HELMICK - Hex Nut - Inch" family name. (Look at the picture I attached in my original post.)
However, that's the only thing that's wrong. If I select the default "Hex Nut - Inch" family through Bolted Connection Generator, it IS my custom "HELMICK - Hex Nut - Inch." (Look at my picture attached to this post)
Why does it not show my custom family name, but when I select it, it IS my custom hex nut?
This may be confusing to others if they go to place a "HELMICK - Hex Nut - Inch" with the Bolted Connection Generator and they can't find it.
IV2012
Windows XP SP3 32-bit
Intel Core 2 Duo 6400 @ 2.13 GHz
Nvidia Quadro FX 3450/4000 SDI 256MB Vram
2 GB Ram
160GB HDD
