I understand you can use the filter to hide the work features in the browse toolbar, but is there a way to turn the visibilitie off in the actual assembly rather than going through and manually turning them off?
Thanks!
Inv. 2011
You can use these keyboard commands to toggle the visibility of work features:
ctrl+] origin plane
ctrl+/ origin axis
ctrl+. origin point
alt+] work plane
alt+/ work axis
alt+. work point
Dave
...good luck remembering all those KB shorts
...how about adding the "Object Visibility" pull down menu (from View Ribbon Panel) to your Quick Access Toolbar..then it takes 2 clicks to turn off visibility of ALL work features of ALL parts within an assembly...and back on again!
...down fall is "Sketches" is not included with the "ALL" 😞
I can't find an "object visibility" in the View tab or in the list of commands. Where is this thing hiding?
Wow, I really hate that stuff that hides IN PLAIN SIGHT
Thank you. I am going to use the bejeebus out of this.
Yeah I feel your pain, i wish it included the sketch visibilty in the 'god mode' object visibilty button.
Btw the shortcut to toggle on/off 'All 2D Sketch Visibility' is F10, I am a rookie for not finding this out earlier.
Have now assigned this as a Macro to all buttons on my 3D mouse 😛
The plugin toggle between visibility of Work planes, Sketches, Axes, and Points, without the pain of searching for it in the browser tree.
Simply click on the selected parts and use the show/hide buttons, or click on the interactive check box that will leave your selection on, until you unselect it.
download is free from http://www.kimprojects.com/shop
and a video demo is https://youtu.be/fP2PnJ9V2LM
