but I'd suspect you want "nesting" capabilities.
It would help to further define your needs.
Just curious. Did you check to see what formats the CNC will take? I ask because a company I used to work for used Solidworks and we used Mastercam to interface with the CNC machine. All we had to do was export out the drawings in a .dxf format and Mastercam would read it. Just wondering if this same procedure would work in your case.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
